I have quite a few blank plates to drill and am printing templates from Microsoft Word and taping them on. I then mark the holes with a hammer and nail and then drill, this isn't totally accurate, so any tips on how to improve it would be appreciated
Easiest way to drill accurate holes is with a pillar drill. Even the cheapest jobbie will be miles ahead of any hand held drill.
Tape over where the hole is to be drilled with masking tape, then a good firm tap with a centre punch / nail. Then use a very small drill bit to make a pilot hole for the full size bit.
Sorry if this is obvious but there really isn't much else to it.
I am fairly certain that provided you drill has a standard 43mm drill collar where a side handle can be clamped to the drill behind the chuck this stand will work with your drill.
If you've got quite a few to do, it may pay to make a simple drilling jig. It could be just a bit of sheet steel screwed to a bit of ply. Mark out and drill it accurately, then clamp each plate in turn between the steel and plywood using the screws as a register for accurate location, stick it under your pillar drill/drill stand and away you go.
One marking out job for as many bits as you want......
audio sockets, using gold plated phono chasis sockets and brass blank plates. The stupid supplier told me he could get the rest of the blank plates(I only have one right now) in a weeks time, but it has already been three weeks.
