Joined: 18 Feb 2007 Posts: 5 Location: Essex, United Kingdom Thanked: 0 times
Posted: Sun Feb 18, 2007 11:23 am Post Subject:
Wiring 2 External PIR Security Lights
I need some advise for wiring 2 150W Security Lights, the way I intend to do this is run a 3 core cable from a switched fused (3 amp) box to the outside of the house, this is where I need the advise the 2 Security PIR Lights are identical and the wiring connections are the normal Neutral(N) Earth(E) Live(L)
With a L1 connection as well (This is the one that confused me !)
If I wire the first light as normal to the Neutral, Live and Earth, do I just tee into the Neutral, Live and Earth or do I use the L1 terminal to carry the live feed to the second light and then just tee into the Neutral and Earth.
And at the second Light wire to the Neutral(N) Earth(E) Live(L).
Joined: 15 Apr 2005 Posts: 12850 Location: Yorkshire, United Kingdom Thanked: 21 times
Posted: Sun Feb 18, 2007 1:59 pm Post Subject:
Maybe im not being very clear.
I was thinking the OP might want the lights to operate together, which, providing the PIRs were both rated at 300w+, would be possible by linking the L1s together.
Supply the first light with LNE, then run LNE and L1 to the second light.
If he wants 2 independant PIR lights, then just running LNE to both fittings would be sufficient.
Posted: Sun Feb 18, 2007 11:56 pm Post Subject:
nonono breezer, you misunderstand yet again (not like you!). L1 is where the switched output from the PIR is connected to the light (so theres 2 wires behind it).
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
