DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Two way switch
This topic originated from the How to page called Replacing a one way light switch with a two way light switch
Click here to return to the page called Replacing a one way light switch with a two way light switch.
Goto page 1, 2  Next
  View previous topic :: View next topic
Author Message
Dcgc
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 18, 2007 11:47 am    Post Subject:
Two way switch
Reply with quote Thanks
I am trying to replace a new two way switch to operate the hall and landing lighting. The wiring is as follows:
two red wires, two black wires and two earth wires.
Can anyone advise me of what wire goes where?
Many thanks
Diane
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Feb 18, 2007 11:50 am    Post Subject:
sorry, no.
you need a multi meter to find out what does what.
are you sure there are only 4 wires? (not counting earth)
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Dcgc
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 18, 2007 11:57 am    Post Subject:
Yes that's all the wires there are, unfortunately I had a cowboy electrician!
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 22 times
PostPosted: Sun Feb 18, 2007 12:21 pm    Post Subject:
Re: Two way switch
Many thanks
Diane
It may be easy.....
Is this a single switch plate with two switches on it. Are there two lights that can be swithed individually by these two switches. Are there any other switches that control either of these two lights ?
__________________
Bernard
Sharnbrook
Problem solver, alternate thinker, Agony aunt with a tool box
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Feb 18, 2007 12:25 pm    Post Subject:
poster did say tw way switch, but yes if its just 2 gang then simple
__________________
Forum = Opinions
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 22 times
PostPosted: Sun Feb 18, 2007 12:33 pm    Post Subject:
Look for the simple option first.
An old lady called me to fix a two way switch. I got there found a "two way" switch. On way it was ON and the other way it was OFF
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Sun Feb 18, 2007 1:09 pm    Post Subject:
4 wires you say... no idea...
either has to be 3 wires or 5 wires.. 4 is not an option.... can't be done that way for 2 way switching...
either live in and 2 strappers with the switched live out at the other switch, or live in, switch out and 3 strappers....
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 22 times
PostPosted: Sun Feb 18, 2007 1:43 pm    Post Subject:
It could be an intermediate. [4]
One of the four may not be used [3]
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 22 times
PostPosted: Sun Feb 18, 2007 2:02 pm    Post Subject:
And it is possible for this to be a 2-way setup on one switch.
Cable one carries L and SL from a fitting. Connect to switch one.
Link wire from COM to COM.
Cable two carries 2 strappers from switch two to another switch. icon_wink.gif
Someone posted last week who had this setup.
Back to top
 Alert Moderators
Dcgc
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 18, 2007 3:55 pm    Post Subject:
Just to clarify,
Yes it is a single plate with two switches, one switch should control the downstairs light and the other switch controls the upstairs light.
There is another single switch upstairs that controls the upstairs light.
These did work with the wiring before, just can't get them to work now.
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Sun Feb 18, 2007 4:13 pm    Post Subject:
crafty, that's still 5 wires..
L , SWL, and 3 strappers ( com , L1 , and L2 )
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Feb 18, 2007 4:15 pm    Post Subject:
no it isnt, read it again
__________________
Forum = Opinions
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Sun Feb 18, 2007 5:38 pm    Post Subject:
As crafty has said - this setup is fairly common.
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 22 times
PostPosted: Sun Feb 18, 2007 5:54 pm    Post Subject:
Next time I draw quicker and also use wobbly lines.........
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Sun Feb 18, 2007 8:30 pm    Post Subject:
says 2 way on one switch quite clearly in his post.. which is what i was referring to.
although after re-reading his post he means 2 way on ONE of the switches, didn't read Dcgc's post after his stating 2 switches, one of which is 2 way..
thought he meant linking the common to the other 2 way switch the other end.. which would then be 5 wires...
Back to top
 Alert Moderators
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
2G 2W Light switch with wrong switch direction 5 340 Mon Nov 26, 2007 10:23 am
Loft Light, Switch and double socket 4 440 Mon Nov 26, 2007 3:50 pm
Cooker switch with socket 3 260 Thu Nov 22, 2007 8:52 pm
Time switch wiring 5 260 Thu Nov 22, 2007 6:02 pm
Wiring 10 LED mini lights to a wall switch 3 420 Thu Nov 22, 2007 12:35 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
