Joined: 20 Feb 2007 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Tue Feb 20, 2007 10:59 am Post Subject:
Fence Post ? Concrete or Wood
I am planning to build a vertical boarded fence, approx 2m in height, with gaps in between the boards. Should i use concrete posts or wooden posts ? i have seen a lot of fences locally in wooden posts which look good and are probably cheaper, but i thought they would rot over time ? Does anyone have any thoughts on this ? Soil conditions are clay below the topsoil if that makes a difference
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Tue Feb 20, 2007 11:18 am Post Subject:
Concrete.
They are a bit dearer to buy, and a lot heavier to hump around, but if you have ever had to get a huge lump of concrete out of the ground after a wooden post has rotted and broken off, you will resolve never to use wooden posts again.
For beauty, you can paint the concrete posts and concrete gravel boards (which I also recommend) with dark brown masonry paint to make them blend in with the stained timber. It is much easier to paint them before installation.
Joined: 21 Oct 2004 Posts: 8456 Location: Sussex, United Kingdom Thanked: 31 times
Posted: Thu Feb 22, 2007 7:44 pm Post Subject:
dont think me and john will ever agree on this one!
depends on what look you like. Concrete can look ugly when it starts to break down and spall off, especially near the coast. If you are going to use timber your better going for 4 inch posts. they will last years longer than a 3 inch post. I personally think timber looks better, and i hump out lumps of concrete from fences all the time at work! each to his own though
__________________ have grace to accept what cant be changed, strength to change what can, wisdom to see the difference
Joined: 23 Feb 2005 Posts: 3612 Location: Surrey, United Kingdom Thanked: 24 times
Posted: Thu Feb 22, 2007 9:32 pm Post Subject:
Either or, I'm sitting on the fence with this one.
If any part of the fence backs onto an area where vehicles pass by then use timber. Only takes a small knock from a careless driver and a concrete post will crack. Timber posts are easier to repair/replace.
Joined: 30 Jan 2007 Posts: 21 Location: Clwyd, United Kingdom Thanked: 0 times
Posted: Fri Feb 23, 2007 6:43 pm Post Subject:
With concrete posts the panels can rattle in the wind, and can get a tad annoying. With timber posts, the panels can be screws in tight, so no rattle. Also any repair work due to wind damage is a lot easier with timber posts
Posted: Fri Feb 23, 2007 7:16 pm Post Subject:
you can use wedges to stop that
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
