Lexi01
Joined: 21 Feb 2007 Posts: 2 Location: Australia Thanked: 0 times
Posted: Wed Feb 21, 2007 9:14 am Post Subject: Bath Waste |
Does anyone know the minimum recommended space to allow under a bath for the waste to allow the water to drain freely? Im installing a bath over a concrete slab and am trying not to dig out the concrete...but also dont want to raise the bath too far off the ground. |
Robster_1981
Joined: 01 Jan 2007 Posts: 104 Location: Manchester, United Kingdom Thanked: 0 times
Posted: Wed Feb 21, 2007 10:41 am Post Subject: |
You can buy shallow bath traps for this kind of thing. Only way to know for sure is to offer the bath into position and measure the distance, or do a test installation to make sure it fits before commiting yourself. |
Softus
Joined: 21 Oct 2004 Posts: 19532 Location: United Kingdom Thanked: 6 times
TicklyT
Joined: 30 Jul 2006 Posts: 1873 Location: Hampshire, United Kingdom Thanked: 20 times
Posted: Wed Feb 21, 2007 2:51 pm Post Subject: |
Consider the position of the waste connection to the soil pipe, or through the wall.
Can you maintain a fall of 1 in 40 from the trap to the outlet?
Once installed, will you have room to dismantle the trap if you need to clean it out? __________________ If it isn't broken, keep fixing it until it is |
Lexi01
Posted: Fri Feb 23, 2007 11:17 am Post Subject: |
Thanks heaps for your help Robster_1981 & TicklyT. I've taken your advice and got a shallow trap from the local hrdware store and installed the bath while avoiding digging up the slab!
Softus...the reason I "would want to do that" is that I figured not digging up a concrete slab was a little easier than digging it up!! Also, you say "What if that's the right thing to do? Why would you not want to do the right thing?"
Well, ever considered that there is more than 1 right thing to do??? I.e. options. |
