worcester greenstar 30cdi system
22 Oct 2006
Not fitted a system before. Customer wants a worcester as above. Had a look at the manual and there are 2 different wiring schemes. One for a system boiler with and one without a diverter valve. Whats the reason for this. Also the one without out has two stats on the cylinder , a cyclinder stat and a temperature cylinder stat - can anyone enlighten me on this? The wiring seems pretty straightforward but I'd like to understand the pluses and cons of these 2 variations of this system boiler.
Or am i being a moron and worcester use the same manual for the combi but have not printed system/combi on the front?
No I'm not being a moron they do a separate manual for the combi
Are you quite sure that you really are competent to fit boilers?
Suggest you read the manual again it is the one with the optional divertor that shows a cylinder stat and a cylinder sensor but it uses the word OR between them. Unless the cylinder is right beside boiler go for the one without the built in divertor there will less pipework involved . usually.
Agile- I have fitted boilers before so yes I hope I'm competent if still learning! - I have never fitted a system boiler though and must admit I was not aware of the option of having a diverter valve fitted to one, yes it will mean more piepwork but I assume there is less messing about with the electrics as all the components apart from the cyl stat,prog room stat are in the boiler?
Namsag - thanks for your helpful response- yeah I'll read the manual again, I was trying to read it at too small a res from the pdf file- I'm a doofus.
Wiring is always easier than pipework and wires dont leak.
Way cheaper to run wires than pipes too!
The extra price of boiler with diverter is usually excessive too.
Tony
Yeah , customer also has all required wiring in place as he has a convential boiler on a vented system at the moment. He doesn't want to have his cylinder replaced either which as its about 10 to 12 years old really should be upgraded to part L compliance?
What are the pros and cons of replacing his old boiler with either
a) a new convential boiler( provide for pump overrun)
or b) a system boiler. I 'm really asking about money and energy efficiency wise here.
