DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
!!!!! HELP !!!!!!! 1 GANG to 2 GANG
This topic originated from the How to page called Replacing a one way light switch
Click here to return to the page called Replacing a one way light switch.
  View previous topic :: View next topic
Author Message
AndrewL
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 25, 2007 10:54 pm    Post Subject:
Reply with quote Thanks
I'm trying to change my living room light switch for a 2 GANG swtich. Some professional advice would be much appericated..... icon_wink.gif
The 1 GANG switch I currently have turns "two" light on with the one switch. I want to put in a 2 GANG switch so both light work independently.
I've had a look at the swtich and it is as follows:
1 single RED wire coming in through the wall going into the "COMM" port.
1 gray wire coming in through the wall with one "RED" wire going to the "COMM port" and another RED wire going to the "L2 Port". There is also a GREEN wire (I'me presumming that's Earth) which has a sleeve on it and isn't connected to any port.
My question is am I able to change the above swtich into a 2 GANG swtich and if so how can this be done?
Andy
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
C&GStudent
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 25, 2007 11:08 pm    Post Subject:
Hi Andrew,
This is probably quite a complicated DIY project. You will need to be able to identify all the cores at both lights. They will be interconnected, and you will have to separate them. You will then have to run a second switch cable from the one light which isn't switched to the old switch position.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Feb 25, 2007 11:20 pm    Post Subject:
look in the sticky to see how its done, then you can decide what you want to do next.
it will need some altterations. can you also confrim deny how may wires (not counting eaths) at the swithc, i make it 2, but your description is a little "confusing"
c &g student, its not that simple, it never is.
idealy you are right, but chances are 2nd light is looped off neutral and swithched live, running a cable from this light to the switch wont work, he needs to change the live feed from switched live to live
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Pens
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 25, 2007 11:23 pm    Post Subject:
You could try the following with the power off
On your new switch put the wire that is currently in L2 into the one mark Com. Add a link from this to the other Com
Split the other two cable that are currently in the the Com and put one in each of the L2's on the new switch.
If the lights don't work put it back as it was and call a sparks.
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Mon Feb 26, 2007 6:58 am    Post Subject:
I agree with pensdown - Try that first, that was my first thought when reading your post. The sinle red on it's own is likely to be the sw live to the second light.
To confirm, you could describe what cables you have behind each light fitting.
Back to top
 Alert Moderators
AndrewL
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 26, 2007 8:46 pm    Post Subject:
Just to confirm:
In one of the lights there seems to be two red wire going into different ports, a black wire going into another and an earth wire also.
In the other light there seems to be wire "madness" icon_eek.gif there is 3 red wires going into a comm port and another red wire going into another port. There is also 2 black wires going into 2 different ports (I think) icon_confused.gif and also an earth wire.
If it is as described above will the pervious method work?
Andy
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Mon Feb 26, 2007 8:50 pm    Post Subject:
so not counting the earths, you have 3 wires?
can you turn this light on from "a" and off from "b"? and vice versa?
anyway, it will need extra cables putting in, since yhe 2nd light is looped off the first, see the sticky posts to see how it is done
__________________
Forum = Opinions
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Mon Feb 26, 2007 9:03 pm    Post Subject:
Sounds like the second light has all the lives from the T+E's in a seperate terminal, leaving a single live with grey sheath as thw switched live for this light from the switch.
Go with the method described above, if i works, great. If not, call a spark, or ask more advice here icon_wink.gif
Back to top
 Alert Moderators
AndrewL
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 26, 2007 11:08 pm    Post Subject:
Cheers guys will try that over the weekend when I can work during the day so I can turn the electric off..... It would prob be a good idea or I'll get fried..... icon_eek.gif
Just one other question.... the new switch has one comm port for each button and 2 ports for each button on the other end which says "1 way" and another says "2 way"
I should be connecting the wires which are currently connected to the Comm port to the "1 Way" right....? icon_confused.gif
Or should the the two wire currently in the comm port go into the "2 way" port?
Back to top
 Alert Moderators
Pens
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 26, 2007 11:30 pm    Post Subject:
Thats right, one in each.
We're all guessing that the guy that wired your switch put the live feed in L2 which you're now going to put in the Com and link to the other Com of your new switch. The other two wires could be the switched lives, one to each light but that might not be the case.
But as long as the power's off when you do it you can't come to any harm and if it doesn't work when you restore the power come back with some pics.....then it gets far more complicated
Back to top
 Alert Moderators
AndrewL
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 27, 2007 8:36 am    Post Subject:
will give that a go over the weekend...... if that doesn't work I think it would be a good idea to get in a sparky or just leave it alone.....
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
two gang problems 8 320 Sat Nov 10, 2007 12:46 pm
Do 1 To 2 Gang Socket Converters Work ok 4 220 Mon Nov 05, 2007 8:29 pm
1 Gang 2 Way dimmer switch problem 2 380 Tue Nov 06, 2007 1:05 am
2 gang dimmer 3 300 Sat Oct 27, 2007 4:07 pm
3 gang intermediate switch? 10 1580 Tue Nov 27, 2007 12:31 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
