Baxi Barcelona
1 Mar 2007
Yorkshire
Hi have a 7 yr old Baxi Barcelona which keeps cutting out after about 30 mins of running - resets once has cooled down. Engineer has replaced pcb today and same problem happening. will work for a bit longer if turn down settings to v v low. any suggestions?
inner case seal damaged causing fan stat to go off?
think its this model that does this.
primary sensor can go too, i ve had that before and not the fan stat, you can bridge them out to test
pipshady said:
primary sensor can go too.
Confused.
What do mean by primary sensor?
Do you mean the flow switch?
If so why would this 'reset once cooled down'.
Gaz
Started fiilling in those WD 45 46 forms yet?
thanks guys - engineer coming again in the morning - will show him your suggestions and let you know what happens!
most likely the remains of the case seal have turned to dust and are lying at the bottom of the case.
