Joined: 02 Jun 2005 Posts: 10887 Location: Cumbria, United Kingdom Thanked: 39 times
Posted: Fri Mar 02, 2007 8:58 pm Post Subject:
Be prepaired for a divorce too, if you use a grinder on concrete it creates a bit of a mess too!! (OK, a bit of a mess is probably putting it a bit lightly)
Joined: 22 Feb 2007 Posts: 11 Location: Sussex, United Kingdom Thanked: 0 times
Posted: Fri Mar 02, 2007 10:40 pm Post Subject:
What about back boxes
Sorry to piggy back off of someone else but it is an appropriate place to ask what about back boxes ?
The average brick is 10cm thick and even the shallow back boxes are 25mm, so a 35mm back box or a 47mm cooker box will easily be more than a quarter of a brick thick.
Once again sorry for the piggy back but I would be interested to know.
Joined: 19 Jan 2007 Posts: 543 Location: Cheshire, United Kingdom Thanked: 0 times
Posted: Sat Mar 03, 2007 9:32 am Post Subject:
Re: What about back boxes
thanks
Yes, but you'll probably have at least 12mm of plasterwork on that brick so you're only sinking the box 23mm into the brick.
Joined: 26 Sep 2006 Posts: 672 Location: London, United Kingdom Thanked: 6 times
Posted: Sat Mar 03, 2007 9:36 am Post Subject:
The regulation refers to cable chases, not to cutouts for back boxes.
The cut out for a back box is not very wide or high, so will not significantly weaken a wall even if it is 50% of the depth - after all, you can take a full brick out of a wall for an air vent with no problem.
A chase for a cable, on the other hand, will run for a significant portion of the height or width of the wall, and cutting it too deep will weaken the structure.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
