DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Overflow Pipe outside just started dripping?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Jaarus
from United Kingdom
PostPosted: Sat Mar 17, 2007 10:13 am Reply with quote
Hello,
Hoping someone can attempt to identify the problem. I am certainly not a plumbing expert - most I have ever done is replacing taps and fitting an electric shower in my parents house.
Last night one of the overflows outside my house started dripping and this morning its still dripping (I say one as we have 3 next to each other on the exterior wall) The water dripping is cold - not sure if that helps!!?
After a bit of exploring I think the three are from the upstairs toilet, the hot water cylinder and the black box (cold water tank?)
I have checked the toilet its not that - water level is fine.
I have opened the top of the black box - the water level looks very low to me but not sure how high it should be! (when I lowered the ball and water came out - when I stopped pressing it stops) But water level is nowhere near the overflow.
So I assume that leaves the culprit as the hot water cylinder?
Am I right in thinking that?
What should I do?
Anything else I should check?
Thanks in advance for any assistance.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Sat Mar 17, 2007 10:20 am Reply with quote
asfar as i know hot water cylinders do not have overflows.
you yourself said the water is cold.
it may be the header tank for your hot water cylinder.
i suggest you follow the pipe backwards and see what it is connected to and then post back.
but do rememebr the pipe on the left outside will be the pipe on the right inside (assuming you are outside looking up, then inside looking out)
Back to top
 Alert Moderators
Jaarus
from United Kingdom
PostPosted: Sat Mar 17, 2007 10:59 am Reply with quote
It looks like this:
http://img83.imageshack.us/img83/3618/dripnv5.jpg
If perspective is the same.
Do you mean the pipes actually switch sides under the floorboards?
Is it safe to remove the plastic cover on the hot water cyclinder so I can check visually if its that - tried and didnt give so wondering if its sealed on there?
Thanks for you assistance by the way! icon_smile.gif[/url]
Back to top
 Alert Moderators
BoxBasher
from United Kingdom
Thanked: 2 times
PostPosted: Sat Mar 17, 2007 2:15 pm Reply with quote
[/url]
No, but anything on your left hand side from the outside will be on your right hand side from the inside (like a mirror)
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Just started level 2 technical certificate at college. 16 1300 Sun Sep 16, 2007 8:11 pm
Ideal Classic Boiler - Just started to make a whirring noise 18 6000 Mon Dec 17, 2007 11:07 pm
new plumber getting started 8 660 Wed Apr 09, 2008 6:33 pm
How do you get started if you'e new to the uk... 30 1880 Thu Mar 22, 2007 7:43 pm
Severe Water Hammer Just Started 3 900 Thu Aug 10, 2006 11:50 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
