plastic/composite coving
9 Apr 2006
Middlesex
Hi.Is the plastic/composite coving any good or should I stick with plaster coving?Thank you.
Depends what you type of "plastic/composite coving" you mean.
Also, it is the same with what type of "plaster coving".
In other words, what makes etc are you reffering to ?
If the Emafyl coving is hardwearing then use that.
You can now get solid poly coving from other makers also.
Is the Emafyl solid ?
Yes the Emafyl is in a solid form its almost like plastic/fibreglass,it is very much like upvc cladding material.
