jt240_1
Joined: 24 Mar 2007 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Sat Mar 24, 2007 9:52 am Post Subject: 2 Gang 1 Way Dimmer |
I am trying to replace a 2 Gang 1 Way switch with a dimmer switch. Both sets of wires have an earth cable however the metal varilight dimmer only has one earth terminal. Can i connect both earths from the seperate lights to the same terminal? |
bernardgreen
Joined: 03 Nov 2006 Posts: 3611 Location: Bedfordshire, United Kingdom Thanked: 22 times
Posted: Sat Mar 24, 2007 9:58 am Post Subject: |
Yes both earth wires to the one earth terminal.
If the back box is metal then use a length wire to connect the earth screw of the back box to the earth terminal of the dimmer so three wires to that terminal
use green yellow sleeving on the earth wires |
jt240_1
Posted: Sat Mar 24, 2007 11:01 am Post Subject: |
Thanks very much. |
