Joined: 26 Mar 2007 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Mon Mar 26, 2007 10:54 am Post Subject:
Damaged cable - fix or replace?
I managed to drill through a mains cable (idiot I know) over the weekend, which powered the booster in a storage heater. I repaired the wire using a connector block and covered the joint in insulation tape.
First question is will this be a sufficient long term fix (it was a tight connection as there wasn't much slack in the wire) or is it worth replacing the whole cable? Second, is it ok to plaster over insulation tape?
Joined: 17 Nov 2006 Posts: 1680 Location: West Glamorgan, United Kingdom Thanked: 0 times
Posted: Mon Mar 26, 2007 11:59 am Post Subject:
ALL connections must be accessible unless they are made by soldering/brazing or by compression tool (crimps). It is best if all joints even those mentioned above are accessible because no joint is perfect but it isn't a requirement.
Insulation tape is not a good enough covering because it dries out, the adhesive fails, it unravels and you are left with exposed joints.
If it is possible then replace the whole cable, if not either leave the connector blocks accessible (cover with a blanking plate or a picture or something.) But if you must cover it over then crimping with heatshrink is the way to go.
Joined: 14 Dec 2007 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Fri Dec 14, 2007 10:34 am Post Subject:
I have just damaged a cable in my kitchen for my extractor hood putting in some new shelves . The cable was black and red. Can I replace the cable even though I would have to use new colours and is this notifyable as I am only replacing what is there?
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Fri Dec 14, 2007 10:38 am Post Subject:
IIRC replacing cable for an existing circuit is not notifiable even in a special location. Remember to stick the appropriate label next to the CU to warn people that both color codes are in use.
Part P is a bit confusing in this regard. Some stuff is notifiable whereever it is. Some stuff is notifiable in special locations, on special installations and in kitchens and some stuff is only notifiable in special locations.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
