DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
No water through Bathroom cold taps
This topic originated from the How to page called Cutting off the water supply
Click here to return to the page called Cutting off the water supply.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
kjt
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 29, 2007 10:40 am    Post Subject:
Reply with quote Thanks
After turning the cold water supply off to drain the hot and the cold system due to a hot bath tap which would not turn off. after restoring the cold water supply there was no cold water coming through the bathroom taps. The kitchen cold tap was okay with full pressure.
There is not even a noise that you would associate with an air lock of some description.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
BazThePipeman
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 29, 2007 2:29 pm    Post Subject:
Do your bathroom cold taps connect to a pipe that runs to a cold water storage tank ?
Have you re-opened all valves on this connecting pipe ?
If its just this length from which no cold water is running yet other cold taps from the storage tank work then it sounds like you've got a blockage in this length somewhere. Probably some filth from the bottom of the tank.
Back to top
 Alert Moderators
Timmyturtle
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 29, 2007 6:41 pm    Post Subject:
Or an airlock
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 9 times
PostPosted: Thu Mar 29, 2007 6:46 pm    Post Subject:
If you have a hose pipe & can get the hose to the tank, then put the house pipe in the tank into the outflow of the cold, turn on the hose & you should sort it. If that is not possible then wait & you will get more ideas.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Thu Mar 29, 2007 7:29 pm    Post Subject:
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 9 times
PostPosted: Thu Mar 29, 2007 7:38 pm    Post Subject:
Softus..I dont claim to be a plumber, as a diyer I know it works. If you read my post it did say wait for other ideas. SO WHERE ARE YOURS.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Thu Mar 29, 2007 8:16 pm    Post Subject:
I didn't say that it wouldn't work.
Quote:
SO WHERE ARE YOURS.
Littered all over the forum.
Back to top
 Alert Moderators
Hudd3
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 29, 2007 8:25 pm    Post Subject:
Sounds like an airlock.... could try blowing back up the tap or connect the hot and cold taps turning both on and see what happens.
For info,plumbers will try anything once .... as long as the airlock will clear
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 9 times
PostPosted: Thu Mar 29, 2007 8:51 pm    Post Subject:
Quote:
SO WHERE ARE YOURS.
So why not help & give a link.
Back to top
 Alert Moderators
Hudd3
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 29, 2007 9:06 pm    Post Subject:
give a link to where? .... have I missed something?
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 9 times
PostPosted: Fri Mar 30, 2007 7:40 am    Post Subject:
Softus could find 1 if the many posts he is refering & point you to it. You never know maybe he will, I think we got him on an off day. icon_lol.gif
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Fri Mar 30, 2007 8:11 am    Post Subject:
Two words - wet vac.
And if you don't have a wet vac, use a dry one with the vaccus interruptus method. icon_wink.gif
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
hot water coming from cold bathroom taps. 2 380 Mon Jan 14, 2008 7:01 pm
No Cold Water going from tank to Bathroom Taps... 3 1620 Wed Apr 09, 2008 2:11 pm
Blocked Cold Water Taps In Bathroom 4 960 Sat Nov 06, 2004 3:00 pm
No Hot Water from Taps in Upstairs Bathroom 2 180 Wed Dec 31, 2008 11:25 am
Almost boiling water out of bathroom taps 6 680 Mon Dec 24, 2007 12:32 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
