The programme starts as normal and then freezes in wash mode and the water isn't heating up. This first occured when my power RCD tripped. Has the element blown or is there away of resetting?
Thanks.
PHIL M.
Sorry, no reset button on your machine.
Likely causes for no heat on your machine are, faulty ntc, faulty heater (toc build into heater) broken wiring in the door or at worst a faulty timer.
