Thanks Scotsman
But when I started the machine on the spin cycle right at the end of the programmer it did spin then drain and then start clicking round ....... does that still mean the motor?
The error code F02 means - Motor jammed or tacho detached. You need to check wiring to motor, module and check the tacho. But generally when you get the 2 flashes you need to change the motor but you might get lucky and it could be a wire.
