DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
toilet block
This topic originated from the How to page called Clearing a blocked WC
Click here to return to the page called Clearing a blocked WC.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
jennirob
from United Kingdom
Thanked: 0 times
PostPosted: Fri Apr 06, 2007 10:21 am    Post Subject:
toilet block
Reply with quote Thanks
My toilet fills up when i flush it. I\\\'ve tried plunging but not worked what should i do next before i call a plumber like a damsel in distress! icon_biggrin.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
wonderb0y
from United Kingdom
Thanked: 0 times
PostPosted: Fri Apr 06, 2007 10:36 am    Post Subject:
get your hand down and see if you can feel anything, (with a glove on) or get a set of rods to try and push the blokage down, if its further down you might have to get someone out
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Fri Apr 06, 2007 10:41 am    Post Subject:
unbent coat hanger works
at a push you you coud try a sink and plug hole unblocker
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
jennirob
from United Kingdom
Thanked: 0 times
PostPosted: Fri Apr 06, 2007 10:43 am    Post Subject:
I've done the sticking my hand down but nothing there. thanks
Back to top
 Alert Moderators
dolph
from United Kingdom
Thanked: 0 times
PostPosted: Fri Apr 06, 2007 12:53 pm    Post Subject:
Same thing happened to me two days ago. When I dismantled toilet took pan into garden found a "solid" mass at the top of second bend. I was amazed how solid it was, bound around a ladies personal towel. Dug it out and now OK. Suggest you use the coat hanger idea but turn it as you insert this will break up the "mass". If you can beg or borrow a larger flexible spring type contraption, Aldi were selling them a couple of weeks ago for a couple of quid; these have a "Y" type front which you can turn with the handle.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Want to block off the waste pipe when I remove toilet.help. 4 520 Sat Mar 10, 2007 9:21 pm
Toilet Block - Bleach Block Cage 8 6220 Mon Apr 25, 2005 11:54 am
Britony 80se hydraulic block 2 260 Mon Sep 24, 2007 10:21 pm
Block lead waste trap 5 320 Thu Mar 13, 2008 8:38 am
Sealing tap block to shower bath 3 100 Tue Nov 04, 2008 10:32 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
