Joined: 06 Apr 2007 Posts: 3 Location: Cheshire, United Kingdom Thanked: 0 times
Posted: Fri Apr 06, 2007 4:04 pm Post Subject:
Cables behind Plasterboard
Hi, I am converting my Integral Garage to a kitchen and will be drylining the walls after doing the electrics, will the cables in the walls have to be covered by any trunking etc. prior to the Dot & Dab plasterboard being fitted? - Thanks
Joined: 31 Mar 2006 Posts: 10752 Location: Birmingham, United Kingdom Thanked: 73 times
Posted: Fri Apr 06, 2007 4:20 pm Post Subject:
Providing the cables are routed within the safe zones then no additional protection is required, however most electricians consider it to be good practice to cover the cables with capping, or better still use oval condiut to enable future replacement of the cables.
Posted: Fri Apr 06, 2007 4:46 pm Post Subject:
Cables Behind Plasterboard
Thanks for that, I am new to this site - so hope I am replying correctly!
Joined: 22 Mar 2005 Posts: 644 Location: Devon, United Kingdom Thanked: 0 times
Posted: Fri Apr 06, 2007 10:52 pm Post Subject:
No, I am saying if its not yet a kitchen, then your statement does not apply, although the electrical works may require notification, depending on their nature.
Joined: 02 Jun 2005 Posts: 10887 Location: Cumbria, United Kingdom Thanked: 39 times
Posted: Fri Apr 06, 2007 11:44 pm Post Subject:
If I remove my sink, strip the units out and not use it as a food preperation area then technically it wont be a kitchen so am I free to modify socket circuits etc without notification? I could re-classifty it as a store room whilst the electrical work is ongoing. It is the same arguament. The electrical work will need to be designed, erected and inspected for kitchen use, so does the kitchen rule apply?
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Fri Apr 06, 2007 11:51 pm Post Subject:
and the ultimate answer to that question is we will probablly never know for sure. They don't really care too much about diyers, the real cowboys can probablly be convicted on much stronger grounds anyway and the legit electricians wouldn't try a dodge like this in the first place
Joined: 06 Feb 2006 Posts: 212 Location: Cheshire, United Kingdom Thanked: 0 times
Posted: Sat Apr 07, 2007 7:27 am Post Subject:
Hmmmm......
You all have a very good point of view on this and a lot of the problems start at the design stage I.E ...
Step one :Assessment of general characteristics
I.E what will the particular room in question be used for?.
As the room is a blank canvas it isnt anything,at the moment BUT the circuit design and cable sizes will show it intends to be a kitchen I.E cooker control switch,cable size for the cooker, FCU`s for under worktop appliances etc.
Obviously when you inform building control they will ask if any new circuits have gone in and you cant really lie, as your going to be working with new harmonized cable colours and it`s at that point they will ask to see or for you to organise for an inspection and test of the new work.
If you know a spark that is willing to put his/her neck on the line and`trust` you have installed the new circuits in line with BS7671 AND in line with document part P,then your all smiles.
I,personally, NEVER EVER trust anyone enough to sign off their work (unless im carrying out a periodic).
__________________ 17th Edition..here we come!
You can teach people to re-wire a plug but cant teach them manners.!
Posted: Sat Apr 07, 2007 11:53 am Post Subject:
festa wrote:
Hmmmm......
I didn'tknow such a small question would start a large debate, regarding the building regs, I am aware!, I am carrying the conversion out under a building notice and will require sign off from the building inspector - I am intending doing the bulk of the electrical work myself with a final inspection and sign off from an electrician to satisfy the inspector, I am thinking along the lines of changing the distibution board to a new split load board, to enable the kitchen to be on its own circuits for both lights and sockets, i also dont require a seperate cooker feed as the new cooker operates from a normal 13a supply (gas hob).
I also want to put the Fridge freezer onto its own MCB so in the event of a trip whilst say on holiday the Freezer will continue running and I will not return home to the rotten turkey smell as we once had when the freezer was off for 2 weeks.
I don't think the installation of teh distibution board is something I will tackle myself, as I can't find out how to get to the meter to turn off the supply.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
