DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
electric shock
This topic originated from the How to page called Choosing the correct size cable
Click here to return to the page called Choosing the correct size cable.
Goto page 1, 2  Next
  View previous topic :: View next topic
Author Message
ron237
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 07, 2007 10:11 pm    Post Subject:
electric shock
Reply with quote Thanks
I have turned off the main switch on the fuse board, but when I removed a wall socket to replace it, I felt a slight tingle like a small electric shock from the wires when I touched them - What could be the problem
thanks
ron
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Sat Apr 07, 2007 10:43 pm    Post Subject:
Did you scuff your feet along the carpet before touching the earthed accessory?
______________________________
Lynda, moderator
please use the edit button
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Apr 07, 2007 11:19 pm    Post Subject:
I bet he had no intention of putting his finger in his friends mouth. icon_lol.gif
I think softus is trying to say the shock you got was static, the box will still be earthed
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
ron237
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 07, 2007 11:20 pm    Post Subject:
Once I felt this I re screwed the old socket back without changing it, just in case I was to get a shock
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Apr 07, 2007 11:21 pm    Post Subject:
you mean to say you never tested it first to see if it was dead, better it dead than you.
please dont tell me you dont have a meter
__________________
Forum = Opinions
Back to top
 Alert Moderators
markie
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 07, 2007 11:39 pm    Post Subject:
Your on/off switch must work otherwise you wouldn't of posted this question. icon_lol.gif if it didn't then you would of felt more than an slight shock icon_lol.gif
__________________
once a bully always a bully, even more so if your udder-half's a cow.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Apr 07, 2007 11:42 pm    Post Subject:
depends which on / off switch he switched, he may have two on off switches and some one may have switched the lable as to which switch is which switch.
but it was probably static
__________________
Forum = Opinions
Back to top
 Alert Moderators
markie
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 07, 2007 11:44 pm    Post Subject:
__________________
Back to top
 Alert Moderators
ron237
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 07, 2007 11:47 pm    Post Subject:
I had a lamp plugged into this socket, which went out when I turned the main switch on the fuse board off, therefore there should not have been any power going to the socket. So why did I get a slight shock when I touched the wires?
Ron
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Sat Apr 07, 2007 11:51 pm    Post Subject:
DID. YOU. SCUFF. YOUR. FEET. ON. THE. CARPET?
markie wrote:
Back to top
 Alert Moderators
ron237
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 08, 2007 12:06 am    Post Subject:
No there is no carpet
Would there still be a feed from the nutral wire
Ron
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Sun Apr 08, 2007 12:08 am    Post Subject:
Did you turn off using a double-pole isolator (and I don't mean two Eastern European contractors)? If so, then no. If not, then possibly.
Do you, or do you not, have a meter than can measure AC volts?
Back to top
 Alert Moderators
ron237
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 08, 2007 12:14 am    Post Subject:
I turned off both the switched fuse and the double pole main switch
I can get hold of an amp meter Can you tell me what I should be testing with this and how
Ron
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Sun Apr 08, 2007 12:34 am    Post Subject:
That's good.
You should measure the AC voltage between the live terminal and an earth, and between the neutral terminal and an earth. Before and after doing that you should find a way to prove that the meter works, but do it safely.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Apr 08, 2007 12:36 am    Post Subject:
softus, do think we should ask bob transformer his opinion?
__________________
Forum = Opinions
Back to top
 Alert Moderators
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Electric Shock from Kitchen Taps?! 11 860 Tue Sep 19, 2006 12:47 pm
Electric shock in bathroom 9 500 Tue Sep 05, 2006 9:27 am
Electric shock treatment 131 5180 Sun Feb 26, 2006 7:04 pm
Electric shock from Water !!!! 27 1060 Sat Feb 10, 2007 1:49 pm
electric shock 3 401 Thu Dec 13, 2007 9:01 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
