DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Shower Pump Fitting?
This topic originated from the How to page called Installing a shower
Click here to return to the page called Installing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
cbo1170
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 08, 2007 11:16 am    Post Subject:
Reply with quote Thanks
I've just installed a new electric shower in our sole bathroom, which is fed through the cold water supply only, via a 15mm pipe. I've now found that the pressure to the shower is low and the water falls out rather than showers out!! I intend to buy a power pump to increase the pressure and flow rate, and ideally would like to site the pump in the loft directly above the hot water cylinder. The distance from the hot water cylinder to the pump would be around 6-10 feet, I and would like to know whether this would be possible, and what problems I may come across when installing the pump.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Buzzark
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 08, 2007 11:31 am    Post Subject:
If you're adding a pump to the electric shower the hot water tank isn't involved. You can pump from the cold tank instead of feeding from the cold mains to get decent pressure.
I'm assuming you're currently feeding from the cold mains? That's how electric shower are designed to be fed generally. You can't pump the cold mains btw, it's illegal. icon_surprised.gif
Or, you can start from scratch and pump hot and cold from the hot and cold cylinders. You ideally need to meet certain supply considerations mostly for the hot feed to ensure there's no air mixed on with hot supply. Normally done with a special flange or shower take off and the temperature normally should not exceed 65c as due to the low pressure left from pumping, cavitation occurs. (basically the water boils at this lower pressure and temperature and causes damage to the pump)
The fitting instructions included with a Salamander pump give lots of good advice on layout for reliable operation.
http://www.salamanderpumps.co.uk/Download/instructions.pdf
I've heard they are pretty good but only installed mine yesterday. RSP50 - decent for a normal shower, we've nothing special rose/bodyjet wise. Quiet, but I've mounted it on a 300mm square paving slab sitting on top of a layer of rockwool to stop vibrations getting through.
Stuart Turner pumps are also highly recommended but more expensive - I suspect like me, you're not looking at a really high end install.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Fitting a shower pump: solutions to deal with asbestos CWST 2 140 Tue Aug 25, 2009 7:46 pm
fitting a shower pump 5 140 Wed Sep 09, 2009 12:17 pm
FITTING PUMP ASSEMBLY TO MIRA EVENT MANUAL POWER SHOWER 2 140 Mon Sep 14, 2009 6:16 pm
Fitting a pump just for the shower 6 560 Mon Sep 11, 2006 3:24 pm
Fitting shower pump (Plumber needed leicester area) 22 740 Thu Jun 12, 2008 6:44 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
