DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
black plastic pipe
This topic originated from the How to page called Repairing a burst pipe
Click here to return to the page called Repairing a burst pipe.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
9901213
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 10, 2007 12:16 pm    Post Subject:
black plastic pipe
Reply with quote Thanks
the incoming water is coming to my kitchen in a black plastic pipe. The stop valve on the pipe is broken. No worries since i can cut off the water supply from the valve outside. Anyway i would like to replace the indoor valve. The problem is that the water pipe is black plastic pipe and it must be very old since my house is 100 years old. I wonder what kind of pipe is it? Is it safe material and how can i do a joint in it? Similar way as with the new blue plastic pipes?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
noseall
from United Kingdom
Thanked: 71 times
PostPosted: Tue Apr 10, 2007 1:58 pm    Post Subject:
yes joint it as you would blue plastic pipe. it's normally a case of finding the correct or most snug fitting cones and inserts. measure the pipe or better still take a small section down to a local trade plumbing suppliers, they should sort you out.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Approx 21mm black plastic water main pipe. 15 2580 Thu Apr 26, 2007 6:41 pm
Black plastic water supply pipe 3 780 Sat Feb 19, 2005 7:43 pm
Black plastic water pipe?? 7 820 Sun Dec 26, 2004 6:18 pm
Need help identifying black plastic pipe 7 520 Wed Jun 25, 2008 11:01 pm
old black plastic pipe 3 560 Fri Oct 19, 2007 10:11 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
