cass16x
Joined: 18 Apr 2007 Posts: 2 Location: United States of America Thanked: 0 times
Posted: Wed Apr 18, 2007 4:02 pm Post Subject: fuse removal |
I have 5 amp 250v slo-blo cartridge fuse for a power supply to a digitech rp2000 but I can't for the life of me figure out how to remove it. I haven't found any help on the internet thus far. The fuse is held in place by 2 silver looking caps on each end that are soldered to a circuit board and I don't want to break the solder because I don't have an iron. Is this possible? I would appreciate the help greatly. |
bernardgreen
Joined: 03 Nov 2006 Posts: 3609 Location: Bedfordshire, United Kingdom Thanked: 22 times
cass16x
Posted: Wed Apr 18, 2007 4:16 pm Post Subject: |
yes, but as i was researching this power supply unit this fuse blows often because there is no on/off switch on the pedal and it short circuits alot. Everything I read says it's really easy to replace the fuse and that should be done instead of buying a new 50 dollar power supply. I'm confused haha. I don't know s**t about these things |
bernardgreen
Posted: Wed Apr 18, 2007 4:24 pm Post Subject: |
Photo of the fuse if possible. |
tim west
Joined: 27 Nov 2006 Posts: 10443 Location: United Kingdom Thanked: 15 times
Posted: Wed Apr 18, 2007 4:27 pm Post Subject: |
might be a resettable fuse which is not resetting as the fault is still there? |
plugwash
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Wed Apr 18, 2007 7:29 pm Post Subject: |
post some pictures, it sounds like it may be a wire ended fuse. |
Taylortwocities
Joined: 27 Jul 2006 Posts: 4932 Location: Oxfordshire, United Kingdom Thanked: 63 times
Posted: Wed Apr 18, 2007 10:32 pm Post Subject: |
You can get new ones from someone like Maplin, but you'll need a soldering iron and the expertise to use it without frying the circuit board
TTC |
