Zanussi washing machine not spinning
20 Apr 2007
The machine fills with water, takes soap but the drum does not move. The programme moves on automatically at each letting in and letting out stage of water. NO SPINNING! Is this a motor problem? Machine is now 7 years old is it worth getting repaired?
1) Probably, may even only need new brushes, assuming the belt is ok. 2) Possibly.
Could also be a faulty start capacitor if the motor is an induction type. Check belt. Possibly also could be the motor speed control board or "module". No way of testing other than replacement with known good unit. Check out http://www.2ndwave.co.uk/manual.html for useful info.
