DIYnot
Local | Network
   DIYnot > Forums
Local | Network
ravenheat timer problem
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
itchy
from United Kingdom
PostPosted: Sat Apr 17, 2004 1:08 pm Reply with quote
Hi, I\\\'ve got a Ravenheat rsf820/20 combi boiler. The timer keeps loosing it\\\'s information i.e all the programed on off times are gone and the clock time is wrong. Someone recomended replacing the clock.
Any ideas, I don\\\'t want to spend 40 replacing the clock and have the same problem.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Sat Apr 17, 2004 2:41 pm Reply with quote
if it is lsing its info it may be its back up battery (assuming it has one) you would need to see if it has one
Back to top
 Alert Moderators
itchy
from United Kingdom
PostPosted: Sat Apr 17, 2004 2:51 pm Reply with quote
I've had a look at the back panal and there is no place for a battery, the system is wired to the mains. Can an earthing fault cause it to clear? I often hear the boiler making a loud clicking noise, is that normal?
Cheers
Bobby
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Sat Apr 17, 2004 3:09 pm Reply with quote
i never said you could see the battery its probably inside, (did you know the computer you are reading this on has a small internal battery?)
If you can not see it, do not feel confident than its time for a new programmer, to make life easy get the same as you currently have
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Ravenheat 820/20 timer display problem 5 400 Sun Oct 11, 2009 8:55 pm
Ravenheat 820/20 Timer malfunction 4 2480 Tue Oct 18, 2005 10:11 am
Ravenheat RSF820/20 Digital Timer?? 2 760 Sun Apr 16, 2006 10:44 pm
Remote Timer for Ravenheat RSF 820/20 3 520 Mon Sep 15, 2008 7:13 am
Biasi Riva problem with Timer 5 240 Wed Oct 20, 2010 2:58 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
