Joined: 26 Apr 2007 Posts: 4 Location: Lancashire, United Kingdom Thanked: 0 times
Posted: Thu Apr 26, 2007 7:48 pm Post Subject:
DUEL FUEL GRILL & ONE OVEN JUST GONE OF PLEASE HELP
HI IT\\\'S A FLAVEL MILANO DUEL FUEL COOKER TWO OVENS EIGHT BURNERS, WHEN MAKING TEA TONIGHT ONE OF MY OVENS AND THE GRILL JUST WENT OF THE LIGHTS WON\\\'T EVEN COME ON, THE OTHER OVEN AND IGNITION IS STILL WORKING HAS ANY ONE GOT ANY ADVICE PLEASE
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Thu Apr 26, 2007 7:58 pm Post Subject:
Ben56 wrote:
Has it tripped the trip switch?
I don't think it will be that as it is a single appliance and the other oven is still working. I would expect it to be supplied on a single circuit, and if it has gas hob the ovens will probably only be about 10A each.
The clock idea could be right, I know someone with an oven that won't come on if the clock has stopped (e.g. power cut) and not been reset, or of course if the oven timer says "off"
I am also wondering if it has one of those connector blocks with copper links for LH and RH ovens so it can be used in 2-phase supplies in some countries, that might have been loose and eroded. But this would not be the first thing to check. More likely timer or a switch fault.
Posted: Thu Apr 26, 2007 8:11 pm Post Subject:
hi thanks for answering so quicky , yes i have tried re setting clock, as for the fuse my husband he thought the same about two fuses but he has looked and can't seem to locate it have you any suggestions please
Posted: Thu Apr 26, 2007 8:34 pm Post Subject:
hi the cooker is 15 months old but has been in storage for 12 months due to building work it is similar to the one in dixons ,FLAVEL MILANO 1OFRS Rangestyle Cooker the amp is 32 but due to one half of the cooker working perfectly i'm completely baffled i've tried the clock again it appears to be fine , the wiring is quite new probably 12 months old my husband was wondering if these cookers have fuses inside , thanks
Posted: Thu Apr 26, 2007 8:55 pm Post Subject:
There is generally not a fuse inside the appliance. If there was, it would be mentioned in the manual, unless it was part of the electronic controls and not user-servicable.
Provided there is just one cable going into the back, I think it is an appliance fault.
Posted: Thu Apr 26, 2007 9:09 pm Post Subject:
hi the clock is just a clock and minute minder it says nothing about timer in the manual but i have reset it just to be sure yes the other oven is electric and is working fine so is the ignigtion i think i'm just going to have to phone the service number and let them come and charge me the earth
thank you to everyone for all your help
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
