under pressure
Joined: 29 Apr 2007 Posts: 46 Location: Berkshire, United Kingdom Thanked: 0 times
Posted: Sun Apr 29, 2007 1:32 am Post Subject: Fitting new steel bath |
I have bought a steel bath and it comes with legs to fit it.
I am surprised that the fittings do not cradle the bath in any way there are just four plastic pads that stick to the bottom of the bath and they in turn attach to a steel cross member by way of a couple of nuts, one cross member at the back of the bath and one at the front is this the normal fittings for a steel bath ?? It does not seem very stable to me at all and there is no indication if where on the bath the pads should rest. |
confidentincompetent
Joined: 31 Jan 2005 Posts: 1205 Location: Dorset, United Kingdom Thanked: 0 times
Posted: Sun Apr 29, 2007 10:11 pm Post Subject: |
If theres no cradle, you need to construct a subframe from timber to steady the bath roll, all way round.. Last one I did had no cradle tho it was plastic Villeroy bosch ( spellin  ). I dont do much refit stuff now but think this type (cradle less) is now quite common with foriegn stuff. Think others may give more info.....
Good luck
John |
