DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
run tap before shower?
This topic originated from the How to page called Installing a shower
Click here to return to the page called Installing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
ae106400
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 29, 2007 11:08 pm    Post Subject:
Reply with quote Thanks
Hi we had a shower put in a while ago but we have to run the hot tap on the basin before any hot comes out of the shower. If you just run the hot on the shower it will run cold for ages and not get warm. Also a pump was put on underneath the bath in a bathroom on the same floor that is now tiled in but the pressure on both showers is rubbish.
Any ideas?Thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Mon Apr 30, 2007 12:10 am    Post Subject:
As an example of an explanation that fits your symptoms, you might have a negative head pump, with a depleted expansion vessel, that isn't reliably detecting flow and therefore not always (or ever) turning on.
However, you haven't yet provided much information about your system, so...
Where is the cold and hot water stored before being fed to the pump - i.e. relative height to the shower head?
And does the pump actually run when it should?
Back to top
 Alert Moderators
wilhelm
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 30, 2007 7:12 pm    Post Subject:
the flow rate from the shower aint enough, to trip the thing, that operates the other thing, that sends a signal to fire up the boiler to give you hot water .
i reckon.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Mon Apr 30, 2007 7:25 pm    Post Subject:
i reckon.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
Has shower pump been plumbed in correctly with balanced hot and cold supplies or is cold off mains?
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
ae106400
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 11, 2007 4:43 pm    Post Subject:
thanks for the replies,
theres two cylinders on the first floor, one with an immersion in it, then there are like 4 tanks in the roof space, 2 are expansion and the other two i assume one is cold water storage and maybe the other one too?
so cylinders are on bottom floor, showers middle floor and tanks on third floor. Now sometimes shower works and sometimes it doesnt.the pump is under the bath in the main batroom and the shower in the ensuite is the problem, there is quite a long run between the two. the cold is off the mains I think, well the pump doesnt run when the showers just on cold and the cold has a good power to it.
maybe running the hot through the basin tap trips the pump into working so thats why i have to do that b4 turning shower on. But then wouldnt the hot at least trickle through the shower when I turn it on without running the basin tap.
I think the pump is in the wrong place too because the pressure in the main bathroom shower is rubbish, the pump is under the bath , shouldnt it be straight off the cylinder? I dont know what type of pump cos its tiled in
thanks for your previous replies
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Shower Install Help!!! 10 520 Sat May 24, 2008 11:43 pm
shower water running hot and cold issue, while basin is fine 3 360 Mon May 26, 2008 11:01 am
Electric Shower 5 80 Mon May 26, 2008 2:53 pm
Broken electric shower 35 700 Tue May 27, 2008 4:55 pm
shower pumps 2 180 Sat May 24, 2008 10:05 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
