Having kitchen fitted, and they have piped off the hot and cold water for use with the new sink, dishwasher and washing machine!
However I found to my dismay that when I turned on the hot water tap (in the bathroom) there was strong throughput but no hot water
UNLESS I turned on the central heating which then seemed to heat the water somewhat!!
The pressure in the system is between 1.5 and 2 bar. The kitchen fitter is taking a look at it today, it was only installed last october and have had no problems before!
I am sure all will be well for getting it fixed under warrantee or that my kitchen fitter will figure it out, maybe there is an air gap somewhere or something.
But I did want to see if this was a common issue with common remedies so I can advise, or if its typical of a problem experianced before?
I have tried resetting the machine but to no avail.
