DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Timer switching with pull cord dimmer
This topic originated from the How to page called Installing wiring for an extractor fan
Click here to return to the page called Installing wiring for an extractor fan.
  View previous topic :: View next topic
Author Message
garyskyrme
from United Kingdom
Thanked: 0 times
PostPosted: Wed May 02, 2007 12:48 pm    Post Subject:
Reply with quote Thanks
New bathroom being installed next week. Have all the bits ready for installer including DIMPULL pullcord dimmer. He is supplying a timer fan. Dimmer manual says the switch can be used for fans - I assumed there would be an un-dimmed output to connect to the timer. There isn't.
Does anyone know what the likely voltage across the timer connections needs to be to trigger the timer?
Thanks for your help.
Gary
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Steve
from United Kingdom
Thanked: 22 times
PostPosted: Wed May 02, 2007 12:53 pm    Post Subject:
You need one with an un-dimmed output, any undervoltage might damage the fan.
Back to top
 Alert Moderators
garyskyrme
from United Kingdom
Thanked: 0 times
PostPosted: Wed May 02, 2007 12:56 pm    Post Subject:
The fan itself will be powered direct; it's just the timer trigger I'm interested in.
thanks
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Changing a timer fan to a pull cord fan 4 140 Wed Jun 03, 2009 8:27 am
Bathroom Extractor Fan - With Pull Cord, With Timer 13 1180 Fri Sep 05, 2008 7:54 am
Pull cord dimmer switch - Load/supply help 7 300 Thu Sep 11, 2008 3:19 pm
dimmer pull cord 5 220 Thu Aug 28, 2008 7:19 pm
Can I use a dimmer switch with wall lights WITH pull cord? 4 180 Sat Sep 19, 2009 12:13 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
