Joined: 03 May 2007 Posts: 3 Location: London, United Kingdom Thanked: 0 times
Posted: Thu May 03, 2007 2:51 pm Post Subject:
Shower for hot tank and main pressure cold water
Hello,
I'm only beginning to understand our heating system and am unsure on which shower to buy. We have a fortic cylinder; (no cold water tank in the loft). We have, I've been told, cold water mains pressure and lower pressure hot water.
Any advice of which type of shower to buy in order to balance the two pressures? Any particular product?
Joined: 20 Aug 2006 Posts: 43 Location: Berkshire, United Kingdom Thanked: 0 times
Posted: Sat May 05, 2007 4:48 pm Post Subject:
search for a TREVI BOOST this is the shower to use mains cold water to suck the hot from the cylinder. If the mains is above 2 bar you may reqiure an adjustable pressure reducing valve otherwise the coldness of the mains will make all showers too cold
Posted: Tue May 08, 2007 8:20 am Post Subject:
Thanks, have read up on the Trevi Venturi Boost. Sounds good but need to check that I have a 20mm hot going to the shower and the shower head is high enough above the tank. Thanks for the pressure info. Will have to speak to plumber now and give him the bumpf I've downloaded.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
