Potterton Netaheat Profile start up problem
7 May 2007
Gloucestershire
Returned from holiday and Potterto Netaheat Profile boiler would not fire up.
To start with the fan started, pilot light solenoid went clunk, ignitor started to spark and pilot light lit but main burner did not. On closer inspection of the pilot light I noticed that the ignitor was still sparking.
Shut of boiler and attempted a restart. This time the fan again started, the solenoid clunked in but no spark and no pilot light.
I have the installation manual for the boiler as I installed it in 1990 although gas was connected by a CORGI fitter. Looking at the fault finder chart in the manual these symtoms indicate a faulty electronic control unit. Does this sound right?
Recently one of the solenoids has been making a buzzing sound which is more pronounced in very cold weather and as the gas feed pipe runs along an external wall I assume it is related to cold gas supply. Assume this is a gas valve solenoid problem. Can these solenoids be replaced without disconnecting the valve body itself?
hope you didnt have the cover off when you were checking the pilot!!!!!
the pcb has died
Most likely pcb, but could be leads etc.
Now you've had the cover off you'll have to get your corgi back to check the case seal with a flue gas analyser.
If/when they leak these boilers pump carbon monoxide into the room.
That is a Bad Thing
Found two recently, can't remember how many I didn't check...
That is a Bad Thing
shiver
me too
Anyone got that link to all the pos pressure boilers ever made?
rob884 said:
thanks cm, will have a look
i am pretty sure they are near the back of it
sorry I am waaay too fat and lazy to get me own book
DOnt want to burn useless calories you know ;)
I am having exactly the same problem. Did the OP here ever find out what the problem was - PCB or solenoids?
