Joined: 29 Apr 2007 Posts: 10 Location: United Kingdom Thanked: 0 times
Posted: Fri May 11, 2007 5:05 pm Post Subject:
too much cold pressure for shower balance
me and a friend installed a bathroom but the cold was from the mains and the pressure too much for a good balance in the shower.Its a thermo mixer from aldi he bought . Anyway we put two service valves at the begining of the run for the appliances (hot and cold) and ive now had to put another service valve on the cold after the wc and basin but before the shower.this service valve is almost shut off to equal the pressure.
Whats the deal with pressure reducing valves? i had a look at some pic on the net and they seem massive.i need something better than a service valve to stop the pressure surely.
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Fri May 11, 2007 5:46 pm Post Subject:
you can get a pressure-reducing valve, not very cheap. Just install it in the cold water supply pipe to the shower. I had one on a seldom-used guest-room shower, and it used to seize shut, but maybe they're OK in regular use. I have an idea they are in the £30/£50 range.
Joined: 04 Feb 2007 Posts: 243 Location: Fife, United Kingdom Thanked: 0 times
Posted: Fri May 11, 2007 6:29 pm Post Subject:
only reduce the flow by nipping back valve ,pressure remains constant. Thats why we had to go to and still do at great expense to college which is reflected in our invoices.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
