Joined: 06 May 2007 Posts: 6 Location: United Kingdom Thanked: 0 times
Posted: Sat May 12, 2007 4:52 pm Post Subject:
Moving a socket
Hi I have a double socket and ideally like to move it 1 meter to the left of it current position. The cable isn\\\'t long enough to reach that far can I somehow connect some additional cable?
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Sat May 12, 2007 4:53 pm Post Subject:
how many cables are there?
why exactly are you trying to move it?
if its on the ring (two cables present means it almost certainly is though its good practice to use your multimeter on continuity with the power off to check) then i'd say your best bet is to leave it where it is and run a spur to your new socket unless there is some very important reason to remove it.
Posted: Sat May 12, 2007 4:59 pm Post Subject:
Its on the ring (2 of each present). The house we bought a few weeks ago and some point in the houses life a plumber decided to place a new radiator with the rad valve obstructing the power socket
Posted: Sat May 12, 2007 5:14 pm Post Subject:
mmm, the trouble is you can't just join the wires and bury the result even if you use a type of join thats suitable for burying because if you do there will be nothing to indicate the cables going up.
the easiest option to get a usable socket in that location is to spur a socket off the side of the existing one but having the inaccessible socket still there will look a bit naff.
you could possiblly move the socket upwards but i'd be worried about flexes dropping over the potentially hot radiator.
If you can lift the floor above without too much issue you should be able to move the cables so that one comes down on each side of the radiator (i'm guessing they go off in opposite directions under the floor) and then fit two new sockets with a horizontal run between them but it will mean quite a lot of chasing to first get the cables out of thier old route and into the new routes.
Joined: 22 Jun 2005 Posts: 1141 Location: Birmingham, United Kingdom Thanked: 0 times
Posted: Sat May 12, 2007 5:43 pm Post Subject:
There you go then, one extra socket in the hall can come in handy. Most houses have just one and if you have the telephone out there plus a lamp there's no place to power the vaccy.
__________________ "Shock me again and I'm gonna turn you off"
Life's a beach.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
