DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Fitting replacement bath taps
This topic originated from the How to page called Fitting new taps
Click here to return to the page called Fitting new taps.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
M3Sid
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 13, 2007 4:51 pm    Post Subject:
Reply with quote Thanks
Few questions for you tap gurus out there:
(i) Are all two-hole bath taps standard 180mm apart?
(ii) My existing bath tap mixer (with shower hose) needs replacing and it seems it's only secured using compression joints with the 3/4" hot and cold pipes. Is this normal or should the tap also have been fixed together with the bath using some nut similar to that used on a basin?
(iii) Will it just be the simple case on unscrewing the two nuts to free the tap and screw in the new one? Hoping it won't open up a whole new set of problems.
Thanks in advance for any help.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Sun May 13, 2007 5:05 pm    Post Subject:
1) Usually
2) Should be held on with a back nut, not just the pipe work icon_rolleyes.gif
3) Changing bath taps easy? icon_lol.gif you may be lucky if you have easy and good access, usually you find nuts stuck and previously fitted by King Kong when you try to undo them icon_lol.gif
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
M3Sid
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 13, 2007 5:35 pm    Post Subject:
Thanks for the speedy reply Dave!
Not sure why my bath mixer has got no back nut, it' only held by pipes. It has been for the last 20 odd years and seems very secure by this with no play - tap is leaking hence need for replacement.
So if I get a new replacement tap, I'd need to secure it with an additional nut, would this entail drilling a new hole in the acrylic bath? Thanks again.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Sun May 13, 2007 5:38 pm    Post Subject:
No the back nuts are supplied with the new mixer tap. They just screw on the same thread as the tap connectors go on, but first!
Are you sure you haven't any there already and you just can't see them? I would expect the mixer to be loose, unless it has benn 'siliconed' on somehow.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
M3Sid
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 13, 2007 8:36 pm    Post Subject:
Jeez, your second response was even faster Dave!
I've just had another look under the bath and yes there are back nuts which tighten against the bath - I couldn't see properly at first and thought they were rubber seals. Anyway, it all looks straightforward so will go ahead and order the replacement taps.
Cheers Dave, you're a star!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
HELP! Shower install and bath/taps replacement pipework..... 4 720 Mon Jun 13, 2005 9:36 am
REDUCED FLOW IN REPLACEMENT BATH MIXER TAPS 6 240 Mon May 11, 2009 7:50 am
center bath taps replacement 2 2160 Fri Jul 20, 2007 7:52 pm
Cast iron bath - replacement waste fitting 2 1540 Thu Apr 05, 2007 2:59 am
Fitting bath taps to a basin - is it OK 9 200 Mon Sep 07, 2009 12:16 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
