| Author |
Message |
JohnA666
Joined: 21 May 2007 Posts: 12 Location: United Kingdom
Posted: Mon May 21, 2007 11:10 am |
I'm currently deciding how to replace two flat roofs at home.
They are about 15sq m each, and the felt is falling apart (no leaks inside yet though!)
I've had a couple of felt specialists, Fibreglass and Rubber as well.
Each one thinks their own product is the stuff of dreams, and the other alternatives are inferior.
I've seen the fleece-back EPDM and the Firestone stuff next to it. They both seem thin to me and cat or fox claws would easily poke holes in them (in my opinion). Plus they are pitch black, so in hot summer days they will be far from ideal. In the States they sell special water-based products to paint them white, so heat must be an issue.
The GRP stuff seems slippery enough to deter cats from damaging it, and in light grey colour will reflect a lot more sun than black rubber.
EPDM is quite elastic and will follow some roof movement, while GRP is not flexible and may crack if there is movement.
Both need OSB boards laid underneath them and neither will have any seams in my roof dimensions. If the weather is dry while fitting, both stand the same chances of successful installation (rain can seriously muck up fibreglass from curing)
They all cost similar money, so I am at a loss as to which one is best for domestic use.
Any ideas from the trade? |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
masona
Joined: 05 Jan 2003 Posts: 11900 Location: Essex, United Kingdom Thanked: 78 times
Posted: Mon May 21, 2007 5:21 pm |
Is it possible to put a low pitch roof with roof tiles instead? |
| Back to top |
JohnA666
Posted: Tue May 22, 2007 9:32 am |
I don't think so, the pitch is not steep enough in the kitchen. It starts off roughly where the pitched roof of the rest of the house ends.
The garage slopes a bit more, but no more than 15% I'd hazard a guess. |
| Back to top |
masona
Posted: Thu May 24, 2007 7:54 am |
| JohnA666 wrote: | | I don't think so, the pitch is not steep enough in the kitchen. It starts off roughly where the pitched roof of the rest of the house ends. |
Can you do a photo? |
| Back to top |
JohnA666
Posted: Mon Jun 04, 2007 10:19 am |
I finally decided to go for GRP.
I think it has an edge over rubber on sun reflectivity and robustness in general.
We'll see how it goes.  |
| Back to top |
adybuttress
Joined: 22 Apr 2007 Posts: 9 Location: Nottinghamshire, United Kingdom
Posted: Sat Jun 09, 2007 9:09 am |
shame you went for the grp. Alot of contractors are jumping from that system to epdm. There have been alot of grp roofs failing due to cracking. At first glance the product looks ideal, but it doesnt allow for any movement.
As for claws going through the rubber. Its never happened in 30 years, so i dont see why it should start now.
The white paint hat can be applied to reflect sun is in areas where the sun gets really hot, such as the states, Arabia, spain etc. Its not very popular here, as we just dont have the climate.
Hope these comments help |
| Back to top |
JohnA666
Posted: Tue Jun 12, 2007 2:42 pm |
I still haven't done it, last weekend was meant to be wet (although it wasn't) and as we know installing GRP in the wet is a no-no
I'm not sure if these cracking incidents are due to faulty installation. If it rains while the fibreglass is curing then it will crack.
The thin layer of rubber (like a car's inner tube) just doesn't feel as robust to me, maybe I'm being paranoid... |
| Back to top |
Deluks
Joined: 23 Feb 2005 Posts: 6137 Location: Surrey, United Kingdom Thanked: 258 times
Posted: Tue Jun 12, 2007 5:06 pm |
| JohnA666 wrote: |
Have you ever had a problem with a car inner tube letting water in?  |
| Back to top |
adybuttress
Posted: Tue Jun 12, 2007 9:42 pm |
I know what your saying.Alot of people think this. Its specifically made for flat roofing. Simular to fishing nylon, not very thick but more than does the job. because it is fully adhered if it was damaged, say due to a falling slate, it can be repaired within 5 minutes at a cost of about a tenner.
Ive been involved with this product for 9 years and to honest repaired perhaps 3-4 if that. |
| Back to top |
Zeberdee
Joined: 20 Jan 2007 Posts: 159 Location: Birmingham, United Kingdom Thanked: 4 times
Posted: Thu Jun 14, 2007 2:46 pm |
How do you rubber and waterproof any boxes on a flat roof? the ones that conceal any pipes coming out the wall etc? |
| Back to top |
adybuttress
Posted: Thu Jun 14, 2007 5:59 pm |
Theres a flashing tape called formflash. Its a semi cured rubber tape tahts self adhesive. You prime the rubber first and then it goes on to vulcanise.
Its very easy |
| Back to top |
Zeberdee
Posted: Thu Jun 14, 2007 7:49 pm |
so you do the whole box in tape? some boxes can be rather big. Isn't it best to use offcuts of rubber then seal? |
| Back to top |
adybuttress
Posted: Fri Jun 15, 2007 9:05 pm |
sorry I didnt explain myself properly. You bond rubber to as much area as possible, then flash off all the joints etc with the tape.
hope this clarifies. If you follow this link there is an instalation guide that explains how the whole system goes together http://www.leaking-flat-roof.co.uk/
Hope this helps[/url] |
| Back to top |
west187
Joined: 16 Jun 2007 Posts: 1 Location: Essex, United Kingdom
Posted: Sat Jun 16, 2007 2:18 am |
Just thought ild advise you to go G.R.P all the way . As long as BBA approved resins are used then cracking will not appear.Also you can get 20 ltrs to cure in 5 mins if you wish , so it aint as risky as you think.I been installing G.R.P roofs for over 10 years. plz dont hesitate to email me for any advice.
G.R.P Roofs last forever!
west  |
| Back to top |
JohnA666
Posted: Mon Jun 18, 2007 10:58 am |
Well during to inclement weather the roofs are still undone.
I still haven't seen any compelling argument against GRP, and during hot sunny days I'd much rather have a light grey shiny surface rather than a black matt surface. In the winter it doesn't matter ofcourse.
My cats could get really nasty if they found a soft surface where their claws adhere to, and EPDM might well be such a surface (can't say for sure though)
I also have three soil pipe supports that will need to be screwed into the new surface. The GRP would create a sealed surface around the screwholes, not sure how the rubber would be like. |
| Back to top |
