I have just changed the above switch which operates two lights by individual switches. I noticed that two of the three earth wires were attached to the metal wall box. the third was not attached. I have attached the 3rd to the earth terminal on the chrome metal cover switch which also wraps around the two other bear earth wires.
My methodology is that the chrome switch is scewed into the metal box and the earth conduction is maintained though this and the fact that all 3 wires are touching each other
Also it was a bit of a squeeze, pushing flush the light switch against the wall. I guess the wires are pressed tight against the back of the wall. albeit i have checked that the connections are tight.
Do you think this a safe outcome?
any advice or oppinions greatly recd, thanx
sparks111
sparks111
