We have a Bosch Maxx WFL2000 washing machine which is about 7 years old.
It still works fine, but sometimes at the end of the cycle we get a very slight leak (perhaps half a cup worth) at the bottom right hand side, near where the pump access cover and drain pipe are. It doesn't happen every wash, which is curious.
I have checked under the machine and inside the front casing, and don't believe it's coming from the door seal. Nor can I see any evidence of leaks from any of the pipes.
From the leak location, the obvious candidate is the extendible black hose that can be used to drain off the pump chamber, which also has a very primitive looking, user-removable plug on the end. But again I can't detect any water on this pipe following the leak....
Has anyone had a similar problem?
Any ideas?
Any ideas?
