tshirtjohn
Joined: 03 May 2006 Posts: 25 Location: Glasgow, United Kingdom
Posted: Thu May 24, 2007 10:36 pm |
Ok now that my workshed is built (10x14ft)
Now comes the part of making sure it's well insulated come winter time.
I run a tshirt & signage business so need to keep dampness to a minimum
The depth of the timber frame inside is 65mm so what's the best method for me to start, even in stages as Summer is just apon us. |
tshirtjohn
Posted: Wed May 30, 2007 9:32 pm |
OK I'm going to go with kingspan panels since they seem the best, I'll be looking at getting 50mm thick panels but where is the best place to get them and what one should I get(there is different panels on there official website)
Any help and advice would be great...... might even get some tee's thrown in for your help  |
Deluks
Joined: 23 Feb 2005 Posts: 6414 Location: Surrey, United Kingdom Thanked: 287 times
Posted: Sat Jun 02, 2007 7:40 pm |
Builders merchants would be your first port of call. See if there's a buildbase near you, they sell xtratherm, basically a cheaper version of kingspan, and probably 90% as effective. You could also use eps (polystyrene sheets) much cheaper again but not as effective as the yellow stuff.
Timber cladding is supposed to have a min 25mm gap behind it for airflow, to help it dry out if any moisture penetrates. With this in mind I'd think to add some 1" thick batten to increase the depth of the upright studs, then fix the insulation flush with this and add plasterboard/ply/hardboard etc to line the room. Don't forget the ceiling, same method, and you might also want to insulate the floor also, just lay insulation boards down with t&g osb/chipboard floating on top.
Ventilation is also a requirement, so fix a couple of air vents on opposing walls to keep everything from going musty.
Milk and 2 sugars with my tee please  |
dark_stranger
Joined: 09 Jun 2005 Posts: 71 Location: Kent, United Kingdom
Posted: Wed Jun 13, 2007 2:52 pm |
breezer
Joined: 03 Jan 2003 Posts: 23330 Location: Sussex, United Kingdom Thanked: 24 times
Posted: Wed Jun 13, 2007 6:43 pm |
agree with the ventilation, i also have a tubular heater to keep some electronics warm |
JohnD
Joined: 15 Nov 2005 Posts: 34370 Location: Hampshire, United Kingdom Thanked: 1089 times
Posted: Wed Jun 13, 2007 7:15 pm |
dark_stranger, what's the floor construction? OSB on bats on paving slabs? What supports the OSB? |
dark_stranger
Posted: Thu Jun 14, 2007 7:58 am |
John, you cant really see but there is 2x2 running length/width ways on the floor at stagger intervals to increase overall support. Then the instulation is placed in between. |
