DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Can I add in a PIR to a garage curcuit?
This topic originated from the How to page called Adding a new light and switch
Click here to return to the page called Adding a new light and switch.
  View previous topic :: View next topic
Author Message
captkemo
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 26, 2007 6:47 pm    Post Subject:
Reply with quote Thanks
I have a new garage with exposed wiring clipped to the beams...
Can I 'tap' into this wiring to create a new light and switch or do I have to go right back to the fuse box?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat May 26, 2007 7:26 pm    Post Subject:
easiest is to go to the fuse box, since if the cable is clipped there will be no slack to work with (also depends on what said cable is feeding)
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sat May 26, 2007 8:48 pm    Post Subject:
or maybe loop off from the ceiling rose (if there is one)?
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Sun May 27, 2007 10:16 pm    Post Subject:
it also depends on what size the circuit is at the moment..
if it's a socket circuit then it needs to be fused down..
to use a junction box you only need to "find" about 10mm of slack..
you strip the outer and small sections of the inner where it passes through the box and terminals respectively.. that's the beauty of those terminals.. you don't even need to cut the cables..
the pnly problem then is that the earth would be un-insulated, so you will have to cut that one and sleeve it..
just go for the JB with the terminals in a line and use one of the middle ones..
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
extending a 45A curcuit 17 780 Mon Aug 23, 2004 5:00 pm
will my lighting curcuit disconnect in 0.4sec 17 1240 Mon Nov 28, 2005 12:59 pm
no earth in lighting curcuit 6 2860 Mon Oct 31, 2005 6:48 pm
Old cooker radial curcuit 13 580 Tue Dec 18, 2007 8:26 am
How to install a dimmer switch on a 3 Way curcuit. 5 360 Wed Aug 13, 2008 12:22 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
