Joined: 30 May 2007 Posts: 2 Location: Cambridgeshire, United Kingdom Thanked: 0 times
Posted: Wed May 30, 2007 12:44 pm Post Subject:
Leaking Speedfit Elbow
Hi - First post so pls be gentle ;o).
Just had a new bathroom fitted, all seems OK apart from a very slow leaking speedfit elbow connecting up the bath taps under the bath. I've tried to tighten this up as much as possible by hand - should I get the wrench on to it or should speedfit connections not need such hard force and the leak is caused by a problem with the pipe/connector and I would be better off just buying another elbow. Thanks, Ian
PS: Don't want the fitter back in - we've fallen out over something else
Joined: 23 Feb 2007 Posts: 14313 Location: Norwich, United Kingdom Thanked: 41 times
Posted: Wed May 30, 2007 12:48 pm Post Subject:
Speedfit elbows DO NOT tighten up, they are push fit. What you are tightening is the safety ring that stops them from coming apart accidently. You may find that by just removing the elbow and checking/cleaning and reassembling it will cure the drip. Always make sure they are pushd together straight on and fully home. If this fails then you can replace elbow.
Joined: 26 Jun 2004 Posts: 24311 Location: London, United Kingdom Thanked: 193 times
Posted: Wed May 30, 2007 1:08 pm Post Subject:
Although I would not use plastic pipework myself the fittings are capable of proper joints but ONLY if they are done properly.
The plastic pipe must be cut with a hand cutter and not with a hacksaw. The pipe must be clean and NOT scratched !!! It must be fully inserted !
They do not need to be tightened more than strong hand tight or very gentle tool.
I would suggest you dismantle carefully and see if you can see what the problem is. Do not remove the sealing bits or stainless ring as that would damage the pipe.
If the pipe is damaged the only solution might be to splice in a new length with an undamaged end to use to remake the joint.
They tell you not to take apart joints or to reuse them again. I have never had any problem doing this myself although I am very careful to do it properly.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
