DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Ground Floor WC Waste
This topic originated from the How to page called Drainage Systems
Click here to return to the page called Drainage Systems.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Robbage
from United Kingdom
Thanked: 0 times
PostPosted: Wed May 30, 2007 5:55 pm    Post Subject:
Reply with quote Thanks
Hi
Got ground floor WC directly connected to drain.
Usual problem the outlet through the floor is way too far into room for modern toilet 8" odd.
I started lifting tiles this morning to retile i now have a damned big hole.
Intending to join using flexi coupler to clay pipe. Can i
1) Cut through horizontal existing clay and add plastic short length etc to Use a 90 deg bend to bring new plastic vertically up into room - good option for me as i dont have to start digging outside to get new pipe close enough to wall ... or
2) As 1) but have to use large radius rest bend as the building regs require at bottom of a stack. P.s. this involved digging up garden path also!
Therefore q is does this constitute a stack or not (ps nothing else is connected to it).
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
denso13
from United Kingdom
Thanked: 2 times
PostPosted: Thu May 31, 2007 6:58 pm    Post Subject:
Back to top
 Alert Moderators
Robbage
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jun 09, 2007 12:22 pm    Post Subject:
Hi thanks for that. Sadly the existing clay 90 bend was entombed in concrete the whole way round as well as the pipe at least 1m back towards the drain, meaning it was not possible with the access i had (!) to be able to reveal enough clay pipe minus concrete casing to add a join to for option 1.
So its off to the hire shop to dig the path up for option 2. It seems the whole clay pipe is entombed in concrete but at least outside i can get the whole way round the pipe and concrete lump and carefully chip off concrete to allow a join to go in.
Else it is the whole lot up and new chamber etc - all to move a bleeding pipe 6" inside a cloakroom ouch.
Those reading who have a toilet boxed in away from the wall to mate up to a soil pipe that comes through the floor but a long way out from the skirting etc - take note. In your search for a flush toilet, you might just uncover a can of worms as i have done.
Unless you enjoy a hydraulic breaker and lots of effort and expense that is icon_sad.gif
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Bad smell from ground floor toilet 3 740 Mon Jun 26, 2006 9:17 pm
shower on ground floor off house 2 280 Mon Apr 16, 2007 9:13 pm
Central heating installation with concrete ground floor 6 520 Tue Jul 31, 2007 6:56 am
ground floor radiators not working. 2 240 Tue Dec 11, 2007 11:31 am
wetroom-style shower area on ground floor - advice needed 4 580 Mon Jul 31, 2006 10:20 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
