Having nearly finished my kitchen, in true DIY style I've started on the bathroom and although I can see and have read a lot of threads here on fitting showers, I just want to make sure I have all the bases covered. In essence - I have:
15mm pipework throughout
Boiler (Veissmann Vitroden 100 combi) is next to the bathroom wall - only a few feet away
Cold pressure is great - not measured it, but with the service valves fully open more water goes on the floor than in the sink
Hot - ok, but the curse of combis means it could be better
Fitting a bath filler which is combined with overflow
And a wall mounted thermostatic diverter to flexible shower head
From the threads and a look at water regs. I believe I need to fit a double check valve to the bath and a single check valve to the shower end.
Ok, so the question is:
Where do I fit the double check valve for the bath? Do I need to fit them by the filler, or can they be fitted to mixer inlets? If the latter, do I still need one for the shower head?
As I believe I have a large pressure difference between DHW and the mains fed cold is it worth using Automatic Flow Limiting Valves (if so, what flow rate is recomended)? Or just fit gate valves and balance that way?
As you can see I am not a plumber and so any help would be greatly appreciated. Oh, and if I've blatantly missed something else, feel free to jump in.
Many thanks
Many thanks
