DIYnot
Local | Network
   DIYnot > Forums
Local | Network
vokera maxim fault
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
luke060
from Vanuatu
PostPosted: Wed May 30, 2007 6:58 pm Reply with quote
i have had on going probs with my boiler, first it started loosing pressure from 1 1/2 bar to 0 in about 4 weeks and slowly its got worse, so now i have to re pressure it every day.. searched high and low and cant find any evidence of leaks...
now i cant get any hot water but the radiators work fine. the only way i can get hot water is if i first turn on the radiators before i run any taps.
can anyone help !!!
Back to top
 Alert Moderators
nickso
from United Kingdom
Thanked: 239 times
PostPosted: Wed May 30, 2007 7:33 pm Reply with quote
no hot water is almost certain to be the diaphragm.
are you sure you haven't got water leaking out of the pressure relief valve?
Back to top
 Alert Moderators
luke060
from Vanuatu
PostPosted: Wed May 30, 2007 8:43 pm Reply with quote
is a diaphram expensive and is it easy to fit, and is it possible to test it to make sure, i will try to see if water is escaping from the pressure relief valve (is this the pipe what comes out the back of the boiler to out side)
tks
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 774 times
PostPosted: Wed May 30, 2007 9:38 pm Reply with quote
No, not too expensive. Look for the dv assembly and when you turn a hot tap on see if a pin comes out about 10mm to activate a switch. if it dosen't then diaphragm perished. A lot of manufacturers state that these should be replaced about every 3 years, but in practice most people wait until it fails.
usually a reasonably straight forward job to replace.
Yes that is the prv.
Back to top
 Alert Moderators
luke060
from Vanuatu
PostPosted: Thu May 31, 2007 7:13 am Reply with quote
thanks very much, ill try that today.....
Back to top
 Alert Moderators
luke060
from Vanuatu
PostPosted: Thu May 31, 2007 9:08 pm Reply with quote
problem solved, thanks to all
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
vokera maxim 3 40 Thu Sep 20, 2012 5:58 pm
Vokera Maxim 24E Combi Boiler. No hot water!!! 7 100 Tue Jun 28, 2011 5:01 pm
Vokera Syntesi 29e - Fault 04 - Insufficient Water Pressure 2 320 Mon Jan 18, 2010 2:36 pm
Will changing high limit thermostat help 01 fault (vokera) 2 640 Wed Jan 20, 2010 10:58 am
Vokera 20-80RS Flowmatic fault 14 1500 Wed Jul 11, 2007 8:48 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
