Jules69
Joined: 02 Jun 2007 Posts: 2 Location: Derbyshire, United Kingdom Thanked: 0 times
Posted: Sat Jun 02, 2007 8:25 am Post Subject: Tap Removal Problem |
My hot water tap leaks and I want to change the washer but I can't undo the retaining screw on the tap head. When I tried to turn it, the screw head seemed "soft" and it kind of collapsed. It's now impossible to get a strong enough grip with the screwdriver. Is there a tip for removing the screw? I've tried sawing into the groove with a sharp knife but it barely touched it. I don't really want to replace the whole tap.
Thanks in advance. |
Bambergaspipe
Joined: 09 May 2007 Posts: 886 Location: United Kingdom Thanked: 0 times
unluckykentucky
Joined: 02 Jun 2007 Posts: 9 Location: United Kingdom Thanked: 0 times
Posted: Sat Jun 02, 2007 9:01 am Post Subject: |
drill out retaining screw or just cut off tap head with hacksaw.dont go mad.ensure you can turn off water before starting.
then get tap reviver kit.
see www.screwfix.com search for tap reviver |
Jules69
Posted: Sat Jun 02, 2007 11:27 am Post Subject: |
I managed to wear down groove in the screw with a penknife. I got enough grip to loosen it about a milimetre or two at a time (discovering that if you tighten then untighten continually it seems to help). It took an age to do it, but the tap is free at last!!
I just wanted to say thanks to those who replied. At least on "Googling" for an answer, I discovered this website which is fantastic!
Thanks again. |
Bambergaspipe
