DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Burst pipe - water cutoff valve?
This topic originated from the How to page called Cutting off the water supply
Click here to return to the page called Cutting off the water supply.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
AAAA
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jun 02, 2007 4:12 pm    Post Subject:
Reply with quote Thanks
We recently had a burst pipe at my allotment site caused by vandalism which cost about £350 in lost water before it was noticed and the supply turned off.
Does anyone know of a valve that can be inserted into the supply pipe which will cut off the water when a pipe bursts or is broken? I guess it's got to be something that detects a sudden increase in water flow.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
chr15
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jun 02, 2007 5:11 pm    Post Subject:
That wouldn't work cos turning on a tap at any time would be like a sudden increase in water flow-what is the supply pipe feeding and what is the pipe made of?
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Sat Jun 02, 2007 5:19 pm    Post Subject:
There certainly ARE devices about, which try to loook for extraordinary demands and turn the water off. Haven't kept details but from what I remember reading, one WOULD suit you.
I expect you'd get some false-alarm type shutoffs, but the allotment users would get used to it.
If you go to http://www.bes.ltd.uk/
and do a search on 'water shut off valves' you'll find a couple (and some very cheap hose fittings!). I've seen others which shut off after a long time without a no-flow condition
Back to top
 Alert Moderators
Balenza
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jun 02, 2007 6:31 pm    Post Subject:
Their is one called " Pipeguard".
http://www.mavespace.com/viewpage.php?page=13
This company below supplies this particular one for £52 though you can purchase online via the links given in the above link.
http://www.hpsmerchant.co.uk/products.htm
__________________
If you cant fix it then leave it so no else will !.
Back to top
 Alert Moderators
AAAA
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 04, 2007 6:54 pm    Post Subject:
Thanks to all for the suggestions. Looking at the details of the products has made me think about how any item would work (or not). At the moment protection for each outlet seems to be the most probable way.
To answer chr15 - we have two supply lines each running to about 10 tanks (as for normal loft tanks with a ball float and valve controlling the filling - we keep fit by lugging around watering cans!). I'm not sure what's running under the ground but the risers are 15mm copper pipes.
I think the biggest technical problem is that during heavy watering periods (early mornings and evenings) many people are taking water from the tanks and the supplies are working at full rate to refill them. So obviously a detector just based on flow rate would probably not work. Ideally the solution would be something that could be set to shutoff after a maximum flow rate of x time but the only solutions I've found require mains electrics which we don't have.
Once again - thanks for the suggestions. Any other options welcome.
Back to top
 Alert Moderators
Balenza
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 04, 2007 7:29 pm    Post Subject:
AAAA wrote
Have you went through pipeguards FAQ section ?
What if I want to use an unlimited amount of water?
No problem, just turn the control knob to ‘Hose-Mode’ for hours of continuous water use
Their are a number of different seettings on pipeguard for different scenarios including closed off.
Maybe a simple shut off valve is all that is needed in a locked enclosure. So just turn it off when everyone leaves the allotment.
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
asd cutoff 8 260 Thu Oct 23, 2008 6:18 pm
Boiler won't go off once ignited (until overheat cutoff) 8 1700 Wed Feb 22, 2006 4:05 pm
burst mains water pipe 3 380 Tue Mar 22, 2005 12:17 pm
Burst water pipe/insurance 19 660 Thu May 14, 2009 8:22 pm
VAILLANT ECOMAX BURST PIPE, BAD DESIGN OR NOT. 15 1280 Fri Feb 01, 2008 7:47 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
