DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Repairing concrete window sills
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
Matt38
from United Kingdom
PostPosted: Tue Jun 05, 2007 10:47 am Reply with quote
Our new house has really dire windowsills in need of repair and I am in need of some advice being a novice!
There are two problems, the concrete windows sills are peeling right back to the stone work revealing layers of different coloured paint as well as showing shabby stone work and also the there are deep cracks in the centre of the window sill.
Should I rub off existing paint to the stonework using sandpaper (type?), fill in the gaps with filler (type again?) and then paint. Do I need primer or should 1 coat be enough.
Matt
Back to top
 Alert Moderators
The-brickie
from United Kingdom
Thanked: 10 times
PostPosted: Tue Jun 05, 2007 1:46 pm Reply with quote
Had a similar thing recently, the cills were bricks that were then rendered, I cut back the render and re did it and then repainted.
The trouble with any repair is that it does not get to the root of the problem, if the building is moving (with mine was) the crack will just open up again and the cill being made of smaller parts (bricks) will break.
A better fix would be to remove all bricks (if yours is indeed brick) and recast a concrete cill with a bit of re bar in it to stop further cracks.
Back to top
 Alert Moderators
Matt38
from United Kingdom
PostPosted: Tue Jun 05, 2007 7:29 pm Reply with quote
That sounds far too 'expert' for me to attempt !!! Would anything other than house movement cause the break? the other sills seem to have the break in the same place i.e. right in the middle of the sill.
Also, would flexible filler not move with the broken bricks then if it is just gradual movement? it says it does on the tube icon_biggrin.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Repairing a leaking wooden window 11 200 Fri Nov 22, 2013 7:55 pm
Repairing Crack In Stone Window Sill ? 7 8720 Tue Sep 07, 2010 8:43 am
Repairing garage door 3 3440 Mon Sep 11, 2006 7:32 pm
Old windows need repairing 2 120 Tue Jul 29, 2014 12:12 pm
Repairing sash windows 2 80 Thu Sep 19, 2013 7:43 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
