DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Pump is running dry?
This topic originated from the How to page called Planning a shower
Click here to return to the page called Planning a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
dr__red
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 13, 2007 12:55 pm    Post Subject:
Reply with quote Thanks
We’ve got 2-inlets/2-outlets/single speed dial pump installed next to HWC in the airing cupboard. It is gravity fed, i.e. with cold water tank in the loft. The pump boosts en-suite shower and a bath tub.
From time to time when running the bath the pump switches into high revs and cold water drops pressure considerably, often stops. It is never an issue with hot water. This makes me think cold water tank must be running out of water icon_eek.gif ? Is it likely? When this happens it also takes a while for bathroom’s flashed toilet to refill - I hear how air bubbles struggle through the pipes before we get a flow...
Still I have a hard time to believe into dry tank scenario... I usually let it “rest” for a while, then run cold water with the pump being switched off – this seems to “cure” the issue.
What do you think is a likely cause of the failure and how to rectify?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Wed Jun 13, 2007 1:45 pm    Post Subject:
Certainly sounds as though the cold tank is running dry from what you have said. If you can't believe it why not go into your loft and check it next time it happens icon_rolleyes.gif
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
dr__red
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 13, 2007 1:57 pm    Post Subject:
yeah, it also crossed my mind, unfortunately this usually happens when I'm in the bath or about to get into one. Not exactly in climb-to-the-loft-with-a-torch mood. But I'll take it as a sportsman next time...
Back to top
 Alert Moderators
dom2466
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jun 14, 2007 6:50 pm    Post Subject:
Dr Red, did you go up into the loft with your bathroom on and see if it was the cold water storage cistern that had run dry ??
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
worcester heatslave oil pump running pressure 2 400 Mon Feb 20, 2006 1:17 am
Ravenheat CSI85AT - water pump running but nothing 4 360 Sat Nov 17, 2007 9:53 pm
Constant running pump 18 280 Wed Jun 17, 2009 2:36 pm
Constantly Running Pump 4 600 Sat Feb 18, 2006 3:53 pm
Ideal gas Boiler pump running constantly 5 720 Sun Jun 01, 2008 9:07 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
