DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Gas Fires for Back boiler
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
jimkav
from United Kingdom
PostPosted: Tue May 04, 2004 3:25 pm Reply with quote
Hope this has not been covered elsewhere. I did try searching.
I want to replace the rather old fashioned and ugly looking gas fire in our dining room.
Im pretty sure I have a back boiler heating system that runs the central heating and the gas fire is connected/integral to that.
(fire has a pilot light, we have a water tank in airing cupboard and big water tanlk in loft. Hence I'm pretty sure this is a back boiler system?)
from looking at B & Q it would seem that all the modern looking gas fires do not work with back boilers.
Is this this the case?
I am correct in assuming that to replace the gas fire i either need to:
- buy another back boiler type fire. (and these all seem to be very large ugly things !)
- tear out fire and back boiler system and replace with combi boiler/new fore etc etc etec = expensive and quite disruptive
Any advice would help. Would prefer a smaller, inset type gas fire that doesnt take up as much space and looks a bit more moder.
jim
Back to top
 Alert Moderators
weargas
from United Kingdom
Thanked: 14 times
PostPosted: Tue May 04, 2004 5:22 pm Reply with quote
you are correct in what you assume. The fire in front of a back boiler is not a seperate item, the fire and back boiler unit are classed as one appliance. At one time a few manufacturers used to supply replacement fire front kits but these stopped with the introduction of oxypilots. You can get bbu's with inset fires but they are expensive and the upheaval of a bbu replacement is often more messy (and expensive) than a new combi/fire.
Back to top
 Alert Moderators
walkingonsunshine
from United Kingdom
PostPosted: Wed May 05, 2004 9:58 am Reply with quote
New firefronts are still available from Baxi, some of them are ok, coals and logs behind glass....... but you will still be limited to the outset type. As far as I am aware no one else does replacement fires for their back boilers so if it's not a Baxi some bullet biting may be required.
Back to top
 Alert Moderators
jimkav
from United Kingdom
PostPosted: Wed May 05, 2004 10:26 am Reply with quote
Yeah look like either putting up with the ugly thing or finding a couple of grand for a new combi etc.
My current fire is a baxi and on checking their web site they do have a couple of replacement fires which although better than what I have at 800 - 1000 not that much better! I get a new combi for that although the fitting may be a more expensive and I would need to find a good palce to stick it.
Cheers
Jim
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
tHORN FIRES/BACK BOILER 2 1040 Wed Nov 07, 2007 5:26 pm
Buderus 800 series back fires,makes very loud bang 4 60 Wed Jan 02, 2013 3:05 pm
Oil-fired boiler fires, runs for 75-150 seconds, cuts out 3 660 Mon Nov 23, 2009 2:31 pm
Boiler fires but timer off 2 260 Fri Nov 27, 2009 8:16 pm
Worcester Bosch 240 combi boiler fires and cuts out 12 1720 Fri Oct 09, 2009 8:36 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
