DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
consumer unit and 30 amp fuse
This topic originated from the How to page called Installing a power socket
Click here to return to the page called Installing a power socket.
  View previous topic :: View next topic
Author Message
gedantic
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jun 16, 2007 3:48 pm    Post Subject:
Reply with quote Thanks
Recently discovered ring main downstairs terminated in old 30 amp fuse box,as would be expected!However there is another live cable clamped in this fuse(ie 3 in total).I traced this to sockets upstairs,a connection between 2 double sockets and a spur off each of these,but obviously no ring!!The problem I have is that I need another 3 double sockets upstairs.Can I link the existing with the proposed to make a separate ring for upstairs? Bearing in mind that this would mean cramming another live cable in at the fusebox,and I don`t think its designed to cramp 4!!If you get my drift!!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ricicle
from United Kingdom
Thanked: 19 times
PostPosted: Sat Jun 16, 2007 4:22 pm    Post Subject:
Not a good idea - one circuit/one fuse.
The only options you have are to wire a new ring totally with it's own protective device or extend the existing ring encompassing any sockets that are incorrectly wired
__________________
Empty barrels make the most noise.
Back to top
 Alert Moderators
gedantic
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jun 16, 2007 5:01 pm    Post Subject:
This would mean that all the sockets in the house would be on one ring?
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Sat Jun 16, 2007 5:08 pm    Post Subject:
Or remove the wire feeding those extra sockets and put in a new fuse rated at 20A or 16A. That makes it a legal radial, but you'll be restricted on current draw - should be ok if no heavy loads upstairs.
__________________
TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R.
Back to top
 Alert Moderators
gedantic
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jun 16, 2007 5:23 pm    Post Subject:
Would it be possible to fit a modern circuit breaker unit,as long as I got a sparky to commission it so to speak?!
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Sat Jun 16, 2007 6:41 pm    Post Subject:
If it were me i'd put two rings on one fuse, its not entirely clear if it complies with BS7671 but its not dangerous and if you have and old fusewire CU it probablly doesn't comply with current regs anyway.
Replacing a CU isn't generally a DIY job, Its notifiable under part P, generaly requires someone to pull the service fuse (really the supplier should do it but many electricians do it themselves) and if its done without proper testing its easy to end up with a RCD that always trips.
Best option IMO is to turn the upstairs into a ring, stick it on the same fuse for now but mark the cables somehow so you know which ones belong to which ring. Then fix any other faults you know of then get an electrican to replace the consumer unit with a modern one.
Back to top
 Alert Moderators
gedantic
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jun 16, 2007 7:26 pm    Post Subject:
Many thanks,its more or less the reply I was hoping for!!Incidently when I get the CU replaced there will be old colours and new colours(wiring),if I put a new ring in,that is.Will the electrician still approve it?
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Sat Jun 16, 2007 11:10 pm    Post Subject:
The electrician will probably not approve work you have done. Most are only able (and prepared) to certify and notify work that they have done themselves.
Mixing old & new wiring colours in an installation is acceptable but certain warning notices have to be posted. yous electrician will know what to do.
__________________
TTC
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Sat Jun 16, 2007 11:17 pm    Post Subject:
the electrican would only be certifying the work he did and possiblly record the general state of the installation. Its not his buisness to care who did the existing wiring or when.
Back to top
 Alert Moderators
gedantic
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jun 17, 2007 9:15 am    Post Subject:
Thanks again!I intend to do what you suggest;any thoughts on fitting 4wires in a fuse terminal that appears to be designed for 2!!
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sun Jun 17, 2007 9:20 pm    Post Subject:
It will be a struggle fitting 4 x 2.5mm˛ conductors into one terminal, even more so if the conductors are 7/.029...
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Sun Jun 17, 2007 9:25 pm    Post Subject:
4x2.5mm cables is an overall CSA of 10mm so i'd expect them to just about fit.
failing that put them in a bit of 30A chock block and run a short peice of 6mm into the terminal.
Back to top
 Alert Moderators
gedantic
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 18, 2007 4:20 pm    Post Subject:
Thanks to all .All I need now is some free time!
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Replacing fuse box with MCB-based consumer unit? 9 5500 Tue Feb 03, 2004 6:53 pm
Fuse in Consumer Unit 2 340 Fri May 20, 2005 2:04 pm
Consumer unit and maximum fuse ratings. 18 460 Sun May 03, 2009 7:20 pm
Replacing Fuse Box with RCD Consumer Unit 7 1040 Tue Aug 02, 2005 7:46 am
live wire on lighting circuit when fuse at consumer unit off 13 1400 Sat May 09, 2009 8:03 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
