DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Wall Mounted Bathroom Taps
This topic originated from the How to page called Fitting new taps
Click here to return to the page called Fitting new taps.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
ATFJGS
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jun 21, 2007 2:52 pm    Post Subject:
Reply with quote Thanks
How do you fit wall mounted bathroom taps?? We plan to tile the wall they go onto as well?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
wonderb0y
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jun 21, 2007 4:14 pm    Post Subject:
And i presume your doing it onto a stud wall, otherwise your going to have some fun
Back to top
 Alert Moderators
ATFJGS
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jun 22, 2007 1:30 pm    Post Subject:
Yep - stud wall, so I'm confident of connecting water supply but how do they stay on the wall? If like standard bath taps they screw from underneath... do wall mounted screw from wall side??
Back to top
 Alert Moderators
mark.carline
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jun 22, 2007 1:49 pm    Post Subject:
I built an 18mm playwood box frame that the pipes etc go in and then used 15mm copper screw on straps to hold the pipes in place.
When I came to do the tiling I wrapped the tiles in cling film before sticking them to the wall with tile adhesive and then once the tile adhesive was dry the tiles where then removed, cling film removed and then fixed to the wall just using the tile grout. This gave me a solid back thats exactly the right distance away from the wall to support the tile.
I used this on my Crosswater BASIN 3 HOLE SET as per:
http://www.crosswater.co.uk/productsgalaxy.php
So in future if I ever need to gain access I only need to worry about removing the tile grout.
Looks a very neat job !
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Wall Mounted Bathroom Basin Taps 4 760 Fri Aug 11, 2006 2:30 pm
Extending Wall Mounted Bath Filler Taps 4 620 Mon Jul 28, 2008 10:24 am
wall mounted taps 2 1920 Wed Jan 25, 2006 1:59 pm
wall mounted bath taps 3 3580 Wed Jan 19, 2005 5:36 pm
Wall mounted taps 4 160 Fri Feb 27, 2009 3:06 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
